TDC Sensor Code
Old Jan 28, 2013 | 07:31 AM
nate6631's Avatar
Default TDC Sensor Code
So I've been having problems with my car lately.
The timing feels off and there is very little power below 2300rpms. I had my friend who is almost finished going to school to be a mechanic and we looked at the timing, distributor, I told him he can take the valve cover off if he wanted to look at the cam and make sure there wasn't any wear on it. He did that and said I was right it looked fine to him.
We finally fixed the low rpm power crap with rotating the distributor to the right spot.
This happened before I saw him yesterday probably 3 days ago.
If I gave my car some gas not too much, just enough to go and pass someone the CEL will come on and I jumped the service connector and triple checked the flashes and it is most definitely 08. Could a faulty TDC sensor be my problem with the low power? Or feel like the timing is off? I have a service manual for my car and just wanted to know about the TDC sensor code and if anyone had some advice.
Thanks for the help, to guys at H-T
Car: 1995 Honda Civic EX Coupe
STOCK D16Z6
Old Jan 29, 2013 | 12:31 PM
nate6631's Avatar
Default Re: TDC Sensor Code
No body huh?
Old Jan 29, 2013 | 12:47 PM
Former User's Avatar
The TDC sensor has two wires and is located inside the distributor.
Resistance test the TDC sensor from the distributor side of the unplugged distributor connector (spec = 350-700 Ohms) and test the two TDC wires for a short and open from the ECU connector.
C4st0r_Tr0y
Honda Civic (2001 - 2005)
Aug 12, 2018 08:08 AM
jdm_dc4
Jun 24, 2008 10:30 AM
Anti-Drama Queens
Apr 11, 2006 03:58 PM
wickedxboi
Oct 28, 2003 08:12 PM
SpoolinEK
12
Jun 18, 2002 05:32 AM
