99' EM1-oil burning smell
So Im kinda stumped on this one.
99' civic SI
115k mi
no mods
28 mpg avg= normal
Here is everything I looked over and confirmed.
Oil burning smell *
-only at idle- smell through air vents when set on outside air(of course)
-only at operating temp. no smell when cold (of course)
-no fluids burning on exhaust pipe-anywhere
-engine does not have any oil leaks anywhere. (since I have owned the car I have put a rear main seal/lower pan gasket.)
-No other leaks of any other fluids-coolant/brake fluid/pwr steering.
-*engine is not burning oil- I change the oil every 3000mi- dip stick shows full when I hit 3000miles for the past 6 oil changes.
- **NO smoke out of the tail pipe at all. In any conditions- idle/cold start/operating temp/WOT
- no DTC's at all.
-Engine is completely bone stock.
- I know the previous owner and he did every maintenance at Honda(per service book-older guy in his 50's)
-Only thing I can think of and have not checked yet is PCV valve sticking.The PCV has never been change to my knowledge and rubber seals(on PCV/baffle box) are hard as a rock.
(@ idle in theory = highest vacuum- sucking oil fumes<--oil smell? I know PCV goes into the IM and fumes cant escape into atmosphere. But IDK what else to check out.
RonJ@HT any suggestions?? anyone? thanks
99' civic SI
115k mi
no mods
28 mpg avg= normal
Oil burning smell *
- no DTC's at all.
Re: 99' EM1-oil burning smell
A new PCV is cheap, and it wouldn't hurt you to replace it anyway. I would also closely inspect the length of your exhaust for any signs of cracks or damage.
Replaced donut gasket in front of cat 7k ago, Could not find any black soot/air leak noise at gaskets and welds. Ill be changing the pcv/seals this sat. I thought of this, this is a some what common issue(welds causing exhaust leak/smell on some older nissan's. (im a nissan tech.)
Delicieuxz
04-26-2019 04:04 PM
