Clutch sticks to floor
Re: Clutch sticks to floor
I released all fluid from the slave by loosening the nipple and pumping the clutch so all the fluid was out retightened it and filled reservoir and pumped the clutch until no air bubbles could be seen but the pedal never tightens up just sticks to floor
Its a very simple system actually. Be sure the lines arent leaking so look for signs of leaks as the fluid only goes one way. If theres no pressure with a new master it could be the slaves fault. Did you install the master correctly? Really, its not difficult.
Yea it's pretty straight forward drain the reservoir remove the lines unbolt from pedal and firewall and ur done but I'm just gna replace the slave
I have the same problem, it doesn't stick to the floor, but it's really soft. I've replaced both the master and the slave, bled the $h!t out of it, and still soft. I've replaced the clutch and replaced the bearings in the transmission too.
pair8hd
16
03-11-2020 06:40 PM
dem0nk1d
10-26-2006 12:01 PM
