HEADLIGHT PROBLEM PLEASE HELP !
hey guys i have a bit of a problem i have a 98 ek single cam. i just put H.I.D.s on it little bit over a month ago .. last night they were working fine this morning my passenger side didn't turn on. the hids were installed correctly so that's not the problem than i took the hids off hole kit* and gave it positive and negative from the battery and they turned on fine. so now the problem i think is on the positive and negative adapter it had on i cutt it off and try to wire them up wire to wire and still did not work ???? what can i do ? ???
Re: HEADLIGHT PROBLEM PLEASE HELP !
at this point i cutt off the small adapter where gronud neg and pos was connected too witch now leaves the pos and neg and ground loose , now i just wanna rewire it wire to wire ?
Not understanding really what you said. I would not resplice the stuff together. Where did you cut the Positive wire at? And where do you have them grounded at?
Any pictures of this would help tremendously.
no, no pictures the car comes with a small 3 way adapter where positive and negative and ground go wired too on the actual harness for the headlights. i cut the adapter off and am trying to wire the positive and neg from the lights straight to the repay how do i do that ?
The correct way? Solder the connections and put heat shrink tube over them. Otherwise just get butt connectors and crimp them together, if this method get the connectors with heat shrink on them to seal moisture. Again I do not recommend this way.
right i understand that and i do have heat srinkers but the thing is , when i touch positive with positive on the hids and negative with negativie they do not turn on. but when i do the same on the battery they do.. ! why is that ?
Jonathan_ED3
Welding / Fabrication
13
09-27-2005 07:12 PM
