Losing power to radio
When I shut my car off, I lose power to my radio.
As in, when I get back in the car and turn it on all my presets have been erased and I have to enter the anti theft code.
Any ideas?
Completely stock 94 del sol
Any ideas?
Re: Losing power to radio
I just purchased the car don't know too much on it.
It had some shitty walmart head unit installed. I removed it and put an OEM unit from my other car in (worked perfect in my 97)
None of the wiring is hacked anything.
I'll check the fuse here on my lunch break.
Sounds like a dumb question, but is the horn itself even there? I looked at every fuse on my girlfriends car before thinking to look if it was even there.
Yeah could be an issue with the wires on the steering wheel then. If my memory serves me correct you have to take the air bag off the steering wheel to get to those wires, but they are connected in the column somewhere.
That probably has something to do with it then.
I removed the SRS unit, wiring and passenger airbag.
I wonder if it is tied into the SRS system?
It is not tied into the Srs system, the SRS system is on it's own system and is wrapped in yellow everything with yellow connectors. However if you took the driver's side bag out you may have damaged a wire or disconnected one on accident. I have a spare wheels and airbag at home I will take a look at when I leave work if you have not figured out the problem.
OPs inquire about SRS system being tied into the power system for horn:
probably gonna have to use jumper cables to connect pos and neg leads is that gonna be okay?
and my cruise control has stopped working as well
