Relocating Power Door Locks on EG
Hello,
I need help finding the right color wires under the dash for Power Door Locks. Can someone point to me, where exactly I can feed the wires from to the switch.
Existing Power Door locks (inside the door harness)
New location for the door locks
P.S. The reason I'm relocating cuz I don't want to make a new hole on my door panel. I'm in the middle of converting into Power Windows.
Thank you
Thank you
Oh look, I can change this
Re: Relocating Power Door Locks on EG
Some cars that were pre-wired for the OEM security system had PL wires for the switch that extended into the cabin. If your donor harness did not come from a 94-95 then it won't have these wires and you will need to extend the wires from inside the door, through the connector, to the console where you're putting your switch.
The donor harness came of 1994 civic ex coupe. Can you help me to find the wires? I want to cut the 3 wires w plug in the door harness and run it in the cabin
Thanks
This is an awesome place to put it, just finished my power door conversion but got lucky and got the door panels too, but might relocate it too. sorry im no help tho.
I have the EX panels too, however I decided to keep my panels. I just swapped out the inner panels with my old ones. I don't like where the power door lock is located, so decided to move it to an empty slot
bochincheboy3ek
09-16-2010 10:12 PM
gribbs
04-11-2003 04:52 AM
