rear sway bar for del sol si with SRR tie bar
i searched and didn't find a sure answer really. I have a 93 si that came stock w/ a front sway bar, but no rear sway so i don't have the holes in my LCAs to mount most sway bars. I wanted to know what sway bars were available that could bolt up w/ my stock LCAs and be larger in diameter than the Suspension Techniques 19mm bar. AND also fit up w/ my SRR tie bar.
thanks for any info.
Re: rear sway bar for del sol si with SRR tie bar (sol2nr)
In order for you to attach the swaybar to the lca's
You will need the lca's off of a 94-01 integra(non type r if you dont plan on changing your rear shocks), del sol vtec, 92-95 civic ex sedan or something aftermarket like srr. Because they have the holes. The only other way would be to ghetto rig it somehow as far as I know.
If you want a bigger bar you could go for a usdm itr of jdm itr and both can be found at passwordjdm.com.
Im planning on putting on a rear swaybar on my hatch so Ive done a little research.
Re: rear sway bar for del sol si with SRR tie bar (func-tion)
yeah, i think one of the only rear sway bars for my set-up is the ST ones. I'll definitely notice a difference w/ a 19mm one over nothing right? Or is it worth getting the LCAs so i can get a bigger diameter bar?
You will need the lca's no matter what and yeah going from no rear bar to having one will be very noticable.
Any bar that will fit on a 92-95 hatch or 94-01 teg will also fit your car you will just need to get the lca's
i'm just going to get the ST front and rear set. front is 25.4mm and rear is 19mm. Is it true that the stock 92-95 si front sway bar is hollow and 18mm?
EDIT: Also, Can i put my stock 93 civic si front sway bar on my dad's 97 civic ex?
Modified by sol2nr at 9:44 PM 2/17/2004
If you have srr tie bar, stock itr rear sway bar will not fit because it's too big 21mm if I am not wrong because its made for 19mm, we covered this before in the the past. I also have srr tie bar that is why i am getting rid of it and getting neuspeed lower tie bar and bsq kit because I have stock itr rear sway bar. You need rear lcas from gsr that will fit for your del sol, I got mine for $60. Good luck
Re: rear sway bar for del sol si with SRR tie bar (eEKEGg)
thanks for the info. With a Susp.Tech. 19mm rear sway bar and the SRR rear tie right...clearance wise it should fit, right?
most likely. One thing wiht using the srr lower tie bar, you don't need a beaks or BSQ kit for your sway bar because it comes with some kind of reinforcement built in.
thanks. thats why i ordered it. can anyone else verify that the 19mm ST rear sway bar will be capatible w/ the SRR rear tie bar?
Also, i don't think it will, but can i put my stock si front sway on my dad's 97 civic ex?
Guest
Posts: n/a
i just bought some megan racing lca's so i could hook my gsr sway bar up. theyre on ebay all the time for like $91 buy it now...i heard from people that have them that they are good quality.
https://honda-tech.com/zerothread?id=761147
