! faint thumping coming from rear left tire !
Old 02-18-2004, 11:02 AM
0ptimus prime's Avatar
Default ! faint thumping coming from rear left tire !
Just today i noticed a silent thumping coming from my rear driver side tire. It only happens when i go over little bumps and the suspension has to travel. Can this be the wheel bearing? Any help appreciated, thanx.
Old 02-18-2004, 11:05 AM
Ya@inlinePRO's Avatar
Default Re: ! faint thumping coming from rear left tire ! (Captain Hammerite)
thumping? like metal on metal or....
any aftermarket suspension work?
Old 02-18-2004, 11:22 AM
chads's Avatar
Default Re: ! faint thumping coming from rear left tire ! (kwik2nec)
when was the last time you pulled an e-break?
you could have a flat spot in your tire.
Old 02-18-2004, 12:10 PM
i'm sure it's not s flat spot, it only happens when i run over little bumps. Oh and i switched to Tein SS like last november. It sounds like a little *thud* when i run over tiny bumps. It's definately not metal on metal.
Old 02-18-2004, 02:24 PM
Default Re: (Captain Hammerite)
help?
Old 02-19-2004, 02:24 PM
common guys, somebody has to have had this happen to em before! A subtle thud coming from the driver side rear tire...
Old 02-19-2004, 02:34 PM
B18Cej1's Avatar
im having the same thing i would also like to know. kinda sounds like something in ur trunk is hitting the car or something. mine started hapening when i switched to gsr susp.
Old 02-19-2004, 03:12 PM
jensen's Avatar
Default Re: (B18Cej1)
I've had this happen for 2 reasons. Once my upper control arm (I dont know technical name) was broken and it caused my tire to wear like a plus sign, really wierd. Mostly shaking at high speeds.
The other think I would check is that you have correct torque on your lug nuts. I know that is simple, but check to make sure you're not about to lose a wheel.
Also, If you cut the bushing when you lowered your car you will sometimes hear a little thumping...I always heard it in my 97 ex that had H&R Sport Springs. No worries.
hatmanafro
10-07-2011 05:29 AM
Stykz
10-16-2008 09:01 PM
Built B16A
Honda Motorcycles
07-31-2008 08:49 AM
nomotor
09-17-2004 07:06 PM
Turbo Powa
18
06-30-2002 07:36 PM
Quick Reply: ! faint thumping coming from rear left tire !
