gsr cluster plugs
gsr cluster plugs
alright i just picked up a gsr cluster for really cheap and i was doing a search on how to install the cluster into a 5th gen civic. i looked at the diagrams and it shows that the cluster that they use only has 2 connectors on the back of the cluster(that how i interpreted it cause it only shows them using the B and C plugs). the cluster that i have has three plugs, a 16 pin, 10 pin and a 13 pin connectors. i would like to know if its possible to use this cluster in my civic and if it is possible can anyone provide and diagrams as to how the wiring should be done. i already tried searching and every link i click on they are using the cluster with only two connectors and not three.
Thanks
Thanks
Pooping on children
Re: gsr cluster plugs (vtec94civic)
https://honda-tech.com/zerothread?id=600468 there ya go have fun and post pics
edit: I couldnt find the one for the wiring sorry
but i have three plugs instead of two. is one of the plugs not needed. i've read that post but he did it with two plugs. anyone got pics of a finished wiring harness. thanks
Re: (vtec94civic)
i know that the 5 speed cluster has 3 holes.. but you only need the main 2 plugs... someone correct me if im wrong... but im pretty sure about this..
Re: (hadehatch)
you have to do some wiring to make it work. i have it in my civic but i put the whole dash in. when you do it you may need to splice to make the blinkers work?? good luck.
is one of the connectors green or yellow?? if so that is for ABS = yellow and green = cruise...
there is a harness w/ about 10 plugs maybe that would be in the middle of the cluster, you do not need that.. look at the diagram in the post about and match up the wire colors and eliminate whats not there..
Re: gsr cluster plugs (hybrid94Si)
are u still trying to use the civic plugs to the gsr cluster if so thats your probllem cuz the civic only comes with 2. you need to go to a junkyard swipe ur self some teg plugs & wires and ur chillin. if thats not your problem then i duno
1 Post
you only need the two main plugs.. one on the right, one on the left, the center is not used.
also all the wires match up color-wise minus the White/Blue Charge system wire which hooks up to a yellow wire in the civic. and the orange speedometer light matches up to a Yellow/Blue wire in the civic. if there is no matched color from the integra plug into the civic wiring it isn't used(minus the last two I pointed out).
I did mine last week, the hardest part IMO is trimming up the bezel.. I spent 30min on it and it's still not quite done.
oh yea, this will help you out with the wiring completely.. I just gave you a short-hand version
http://www.geocities.com/Area5....html
thanks everyone, i forgot to get the plugs while i was down at the junkyard so i'm going to have to go back and get them. will ls plugs work or do i have to get the plugs from a gsr?
Re: (vtec94civic)
i believe any 94 and up integra plugs will work. correct me if im wrong though cuz im going tomorrow to the junkyard to pick up a set for myself
thanks
thanks
oem_certified_accord
04-01-2008 06:35 PM
importboi22
05-31-2004 10:32 PM
