won't engage v Tec
Old 06-30-2013, 05:05 PM
Hondaboy30's Avatar
Icon6 won't engage v Tec
I have a 95 civic coupe with a ls v Tec chipped p28 ,, my car won't rev past v Tec engagement starts,, tach and speedometer goes crazy at the same time,, very aggravated. Please help
Old 06-30-2013, 05:07 PM
The Grumpiest
grumblemarc's Avatar
Default Re: won't engage v Tec
Anytime I read these it stems from the fact that the build was not done properly.
Old 06-30-2013, 05:14 PM
B_Swapped93's Avatar
take the chip out and see what happens....sounds like a "mugen" or "spoon" chip from ebay or who ever made it eff'd up badly
Old 07-01-2013, 04:52 AM
Hondaboy30's Avatar
I tried a virgin p30,, new dizzy,,new speed sensor,,I'm activated ,, any shops around Ws, or Lexington
Old 07-01-2013, 05:03 AM
Hondaboy30's Avatar
Aggravated,,lol,, I am going to try a fresh uncut harness today.. If that doesn't work I don't know what to do?????
Old 07-01-2013, 05:37 AM
sleepyaccord96's Avatar
replace the distributor
Old 07-01-2013, 06:30 AM
97_ek_coupe's Avatar
What have you checked so far? Have you checked the basics, like making sure there is proper oil/solenoid is clean/vtec is wired properly?
Old 07-01-2013, 06:48 AM
Dasnegro's Avatar
Sounds weird that the gauge cluster goes funny
Sounds like a poss wiring problem
Do. ALL!! Of your basic checks on sensors and continuity to and from the ecu
Old 07-01-2013, 11:09 AM
apexi_rsx's Avatar
usually when it wont rev up past 3k it is a distributor problem
Old 07-02-2013, 01:20 PM
Hondaboy30's Avatar
It goes past 3,,it goes to 5and as soon as v Tec. Pops ,it won't go further. Just replaced new harness,,same crap....... So make a long story short I forgot to plug in my speed sensor and cel came on obviously but anyway drove it around the neighborhood and v Tec pops with out speed sensor????? Any ideas ,,its not the ecu ,distributor,or wiring harness,,new speed sensor,, ??????
Old 07-08-2013, 01:08 AM
Hondaboy30's Avatar
Come on guys no more recommendation ????
Old 07-08-2013, 01:12 AM
Orangevirus1's Avatar
they recommend check it all.. what more could someone recommend?
check none of it, just keep driving it, eventually it will all fall into place and start working.
Technical Hero
HondaPartsHero's Avatar
So is that the only check engine light you have?
Old 07-08-2013, 07:21 AM
this isn't a distributor problem, its a vtec malfunction. of what I listed, what have you checked?
Old 07-08-2013, 08:31 AM
mikeneamtu's Avatar
I had a buddy who has the exact same build...his vtec would engage then drop out almost instantly...we thought no oil pressure...but luckily another one of my buddies is a genius with Honda's and ended up pulling the ecu and finding out that the ECU was chipped and pronged the wrong way....any, we fixed that and now everytime we hit tec the speedo goes nuts....we are in the process of changing the dash harness due to faulty wiring... So maybe try checking your dash harness...When we figure it our i'll update you and tell you what it was!
Old 07-08-2013, 10:55 AM
I know there is a cable under the hood on the drivers side that the voltage goes with the rpm's. you can see what the problem is by checking the voltage while revving. if the number fluctuates with the rpm's, then the problem is the actual cluster. if not, then the speed sensor or wiring was the issue.
Old 07-08-2013, 11:44 AM
nealnanoHX's Avatar
Look to the Dizzy.
Old 07-08-2013, 12:51 PM
Hondaboy30's Avatar
I have tried my brothers 95 db8 ,dizzy,ecu,speed sensor, I have changed cabin and harness as well as the engine harness and still same bustin out,,I have ran out of options.the motor is 98 ls block with type r pistons gsr head oil pump water pump skunk two intake manifold cosmetic head gasket Hastings rings and acl race bearings, gsr trans built by thang from Conover,,it's not my set or build.any suggestions??
Old 07-08-2013, 12:52 PM
Hondaboy30's Avatar
And yeah that's my only cel
PR8urVtec
05-20-2016 05:19 PM
toolbox21
07-19-2014 03:04 PM
Hatcheys314
03-18-2010 08:34 AM
hfrex
19
09-16-2009 04:42 PM
badassmthr4000
08-13-2007 08:35 PM
Quick Reply: won't engage v Tec
