b16a2 swap question about Intake Manifold
Re: b16a2 swap question about Intake Manifold
I would say yes you can change it. make sure you can do your wiring correct. if your swaping it into an ek mine as well drop in obd2 injectors :D! so you wont have to cut your injecto plugs and put obd1 plugs..
ps, i just had to do the same thing but insted i put obd2 f-series injectors on my ls manifold going into my eg coupe.
Lol you confused me bro so put in obd2 injectors not obd1 in the manifold and I can use the manifold for my 96 ek ... Is their a certain way I have to wire it up since I'm not using the obd2 manifold?
I would go with a P30 intake, it flows a bit better and has a cleaner look since it does not have all that extra crap on it. No need for the fast idle valve ect.
CLICC916
04-05-2005 03:59 PM
