D16y8 swap gone wrong!!! Advice anyone??
So it started of like this recently bought an nice 97 ek coupe... tuned up the second day, let someone drive it arround for fun they ended up braking my engine originaly a d16y7... no big problem found my self a nice soch v tec d16y8 swaped the whole thing out still using the y7 tranny its always being a 5 speed now at the time when I bought the ecu I ended up getting the obd2b? For some reason I am only familiar with obd0, and 1 ok no big effin deal got my self together and looked for the right one to plug and play now it plugs... here's the problem when using the p2e ecu car runs somewhat ok no vtec blah blah anyway when I plug in my P2P ecu car turns over fine then idles like crazy take it for a spin n it boggs nasty to pick up speed swap to the p2e again n it runs better wth is going any advice will be greatly effing appreciate it...
Re: D16y8 swap gone wrong!!! Advice anyone??
IACV & O2 Sensor, the two things I could think of.
Here's more info:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
Here's more info:
DX/LX/CX - D16Y7
Mostly plug and play. VTEC solenoid, VTEC pressure switch and knock sensor will need to be wired in (Figure 6 for OBD2A, Figure 7 for OBD2B). Also the idle air control valve will need to be wire from 3 wire to 2 wire (Figure 6 for OBD2A, Figure 7 for OBD2B). The secondary O2 sensor wiring will have to be lengthened by using an O2 adapter if you are using an EX style catalytic converter. The intake air temperature sensor will have to be relocated in the intake arm somewhere as the Y8 manifold doesn't have a place for it (see figure 8).
That will be the obd2b n I'm still running the stock hardness so leaves me with the obd2a as a plug and play I did everything posted above the 2 wire IACV wired up change the pins on plug a from a 14 to a12 n removed the orange one idk what could be wrong thanks for the reply though.... someone mentione a malfunction on the knock sensor any possibility?
Sorry man I'm all stressed out /= u posted the right one for some reason I swear I saw the obd2b... yeah Idid eeverything in the pic all of it the funny thing I don't understand is why would it run better on yhe P2e instead of the P2P?
Any CEL codes?
Did you read the last bit on what I posted under "misc'
If re-using a CX to DX engine harness, the CKP (crank sensor) has one too many wires for this specific sensor (3 total). Any US 96+/OBD2 DOHC engine has a 2-wire CKP sensor. Simply color match the wires up from the DOHC CKP sensor and leave the 3rd wire disconnected.
Yes I'm getting a cel only thing is that I aing getting my scaner till tomorrow morning let a friend diagnose his car... sorry I will post them up as soon as I get the scaner back in my hands...
http://www.d-series.org/forums/diy-f...g-harness.html
Now, inside the car, route your 2 wires to the ECU. If you have not already done so, do the ECU side of the 2 wire IACV conversion. Take the extra orange wire (that you extended to the knock sensor) and plug it into D6. Attach pins to your 2 black wires and plug the "oil pressure" wire into C15, and your "vtec wire" into A8. Refer to the picture below for plug locations. Plug in your new P2P ECU and enjoy your swap!
Technical Hero
Do you know if your engine is auto or not (IACV will be booted to the back of the intake manifold)?
All else aside the only codes you should throw is:
VTEC
Knock
IACV
You don't need a scanner, look in the FAQ and all you need is a jumper wire or paper clip.
VTEC
Knock
IACV
Fabian@delsol
Engine Management and Tuning
10-10-2014 08:45 PM
