D16Z6 - got an oil leak
OK so I cleaned the engine and tranny yesterday with some simple green and hosed it off dried it with some paper towels and it looked awesome now this morning after a run to the store I smelled some oil burning thought it was the old vw next to me so I get home pop the hood and see this ¶ anyone know where that could be leaking from thanks in advance
Re: got a leak
I guess the old build up was masking the problem and cleaning it just pissed me off know I need to fix it lol I have a slight ocd and it will bug me till its done I'm thinking maybe the dizzy o ring but no leaks inside the cap
Re: got a leak
Did you try and trace where its coming from? You should be able to follow the path of fresh oil.
Since the vtec solenoid is on the back side, I would guess the dist. o-ring...
Re: got a leak
If the internal seal is bad, you'll find oil inside the distributor. Have you removed the cap, rotor, and inner cover to inspect?
Re: D16Z6 - got an oil leak
Vtec solenoid gasket was bought new when I polished it and I found the leak I made a rookie mistake by not adding rtv to the corners when i changed valve covers so it was seeping out from the rear corner thanks for the input guys
jdmsir4dr
07-26-2010 08:09 PM
