neutral safety or interlock switch MISSING!?
Old 07-02-2013, 11:29 AM
willpower102's Avatar
Default neutral safety or interlock switch MISSING!?
A while ago my little crayon looking piece broke off. So I put a bolt in it's place and it works fine. I come to find my car won't start.
Look down there. The bolt is gone.
The switch is missing!
I think I might be suffering from temporary blindness. Anyone have a pic of what this thing looks like?
Old 07-02-2013, 11:45 AM
Ferio Wdm Edition
ferio-ichi3's Avatar
Default Re: neutral safety or interlock switch MISSING!?
Its just a little black piece. I did auto to manual swap, and it didnt come with that rubber/plastic piece, so i used a bolt and nut. No problems or issues.
Old 07-02-2013, 11:46 AM
I'm retarded. It's up further than i thiught it was I was looking at the cruise control switch
Old 07-02-2013, 12:16 PM
Ferio Wdm Edition
Lol, well they both have that plastic rubber thing, i used a nut and bolt On both..and also the clutch switch, and cruise switch look the same. iirc, the clutch switch is slighter bigger than the cruise switch, do You need a pic of The 2 switches?
Old 07-02-2013, 12:31 PM
aw614's Avatar
yeah when those rubber pads break they all break right after another and disintegrate, probably should replace the brake light one too, or you'll have the lights on all the time.
Old 07-02-2013, 12:45 PM
Ferio Wdm Edition
The brakes has a rubber piece also?
Old 07-02-2013, 03:56 PM
Yeah, I actually just checked and realized what I replaced was the brake light one. This clutch switch is going to be a bitch to get to.
Old 07-02-2013, 04:07 PM
Ferio Wdm Edition
Ur better off using a nut and a bolt...it will never come out if its tightened enough. Dont even stress man
Old 07-02-2013, 10:00 PM
Welp. No bolt that fits any nuts I have sadly. I jbwelded two pennies.
Getting the clutch level bolt out was a pita!! Mainly because of harnesses in the way that I couldn't figure out how to remove. Putting them back in was easy peasy. Works a treat now!
Old 07-03-2013, 04:46 AM
aw614's Avatar
Yeah, I ended up giving up trying to get it in there, and had problems removing the pedal assembly and said screw it, and paid a shop to get that installed while I got my alignment. Hoping the rubber stoppers last another 12 years for me lol.
JBweld should hold up better than my tape and penny trick, it worked for 6mo, but every so often it would slide down a bit and I couldn't start my Integra.
striker5661
03-26-2012 05:39 PM
josh352727
08-19-2011 08:54 AM
ke98248
28
06-11-2007 08:49 AM
type B16
09-02-2006 04:08 PM
NateTEG95
12-21-2002 07:09 AM
Quick Reply: neutral safety or interlock switch MISSING!?
