Engine difference???
Old Jun 27, 2013 | 10:59 AM
chillerice's Avatar
Default Engine difference???
Ok guys,
I did this screwdriver trick I saw on youtube about finding rod knocks. Found it in cylinder #1. I'm not sure if I scored my crankshaft in the process because the first time I heard the knock it was at idle and it's always only at idle.
The same morning I drove it about 6 blocks when I started the car then back @2500 rpm to my house and no knocking. Didn't drive it after that only started it to record the videos I posted. I'm very low on cash & was hoping bearing replacement on every rod.
But here's my real question.
I started looking for a similar replacement engine in case I get some money, but does it matter if it came from a car with manual transmission or not? Mine's an auto!!!
And what are the chances the crank isn't scored beyond repair?
Old Jun 27, 2013 | 11:03 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: Engine difference???
so what year and model do you own? What type of engine is in it now? What is your budget? Do you want more power? Do you want to switch to manual? Do you want to have to change wiring?
We can not read minds.
grumblemarc's Avatar
The Grumpiest
Stop guessing and examine the crank. We don't do guessing games here.
If you want to save yourself any hassle get a like-for-like- replacement. The engines are not the problem. The intake manifolds are.
Old Jun 27, 2013 | 11:05 AM
B_Swapped93's Avatar
you could always buy a short block(no head even) and just swap it out, imo that's cheaper/easier then the alternative. no it doesn't have to be from an auto keep your tranny and current head. im guessing this is a Y8 or Y7 we're talking about.
Old Jun 27, 2013 | 11:13 AM
chillerice's Avatar
It's a Y8. Budget is $ 400- 600 or less if It's possible. And I'm not mechanically inclined to take my engine apart plus I lack air tools (if needed)
Old Jun 27, 2013 | 11:15 AM
The Grumpiest
Then you'll blow your budget easy if you can't do the work yourself.
Old Jun 27, 2013 | 11:17 AM
chillerice's Avatar
It's like a engine ghost town here. No one within a 50 mile radius has a engine on craigslist.
I'm noob with the engine block thing. This (short) would come with the rods & the whole bottom end right?
Old Jun 27, 2013 | 11:18 AM
The Grumpiest
Shortblock. Yes.
Old Jun 27, 2013 | 11:19 AM
chillerice's Avatar
I was relating to engine cost Marc. On the mechanic side I was hoping around 1100 total for both replacement engine & labor to put it in.
Old Jun 27, 2013 | 11:23 AM
chillerice's Avatar
Ok I'll look into this shortblock. And if you guys know where I could get one & the average cost. I'd pay for shipping too.
Thank you so much for y'all help!!!
Old Jun 27, 2013 | 11:31 AM
search around I'm sure you know someone who has a hatch/truck that could help you cart it home ,y8 short block shouldn't be more than 200-300$ or so at least a decent shape one.
Old Jun 27, 2013 | 11:59 AM
chillerice's Avatar
I have a truck so that's okay. is there such a thing as a non-vtec y8? I saw this dude asking about Y7 vtec block vs Y7 non-vtec block. Just curious.
And thank you a thousand times for your help.
Old Jun 27, 2013 | 12:01 PM
kyden's Avatar
you can use a y7 block if that's what you're asking.
yup, it's called the d16y7 but it's non-vtec only but you can use your y8 head tho no prob.
Old Jun 27, 2013 | 12:38 PM
chillerice's Avatar
Not really. I want back a complete D16Y8.
What I was asking is if the Y8 block is strictly vtec or there's a non vtec version of D16Y8s.
Old Jun 27, 2013 | 12:40 PM
doctorake's Avatar
Community Builder
only vtec D16Y8s
Old Jun 27, 2013 | 01:02 PM
chillerice's Avatar
Originally Posted by doctorake
only vtec D16Y8s
Ok. Thanks. Just curious.
Old Jun 27, 2013 | 01:06 PM
y7 and y8 share the same bottom end you'd just end up with a "mini-me" which has a slightly higher CR iirc than the y8 nothing special just saying. you can probably get a y7 bottom easier/cheaper than a y8 as ppl let those go for 100-200$.
Drew Nissen
Sep 12, 2014 04:15 AM
dino_add
15
Jun 22, 2011 08:51 PM
93dx
Aug 17, 2005 11:23 PM
BlackJoker
28
Sep 29, 2003 05:37 PM
