Wonder about this oil Leak
Hi Everyone,
I have a 1998 Civic EX manual transmission
This weekend I decided to go ahead and replace my Valve cover gasket, VTEC gasket and the IACV gasket. When I had my valve cover off I decided to retighten (using a torcometer and the engine cold(1 night off)) my head bolts with the specification torque procedure, only a few turned just a bit and just in case I turned the other ones just that little bit to try maintain the same shape.
The valve cover gasket I bought was not the one for this car, it looked pretty similar but I had to cut it and glue it since it was a bit larger than stock. Then I installed it without any sealant.
Today I checked and I have a major oil leak, couldnt tell where since I needed to clean the engine and I had no time. Could it be its leaking from the head? I hope its not, pretty sure the valve cover gasket is not the one I needed.
Thanks!
Thanks!
Re: Wonder about this oil Leak
Hi Everyone,
Thanks!
Thanks!
OK i think your gasket WAS the correct one. When you install rubber gaskets you cannot "slide" your fingers across the gasket as you Lay it into its trough/groove it lays in. you MUST PRESS the gasket DOWN into place. If you slide your hand across it the gasket "grows" and it will not fit and you would have to cut a link out of it so it will lay in and not scrunch up.
i was a bit scared I broke my head gasket when retightening it, but I was very careful I did turn the bolts lets say no more than a 1/6.
Yuta
12-12-2015 05:27 PM
Shaguar47
05-28-2007 08:47 AM
Qwikrex
11-18-2002 02:13 PM
