Bad A/C
Old 07-05-2013, 08:01 PM
EgHatchy96's Avatar
Default Bad A/C
My air conditioning temp got considerably worse after having it recharged at the hobby shop on base where I live. It used to come out at maybe 55 degrees F, now it's consistently pushing out barely chilly air at 75 degrees F. Any advice on how to fix this? Vehicle is a 93 Civic Hatchback CX
Old 07-05-2013, 08:06 PM
instrument's Avatar
Default Re: Bad A/C
Overcharged!
Old 07-05-2013, 08:07 PM
EgHatchy96's Avatar
Default Re: Bad A/C
So basically flushing it, & filling it with the proper amount of R134a refrigerant would fix that? Great, simple. Thank you
Old 07-05-2013, 09:22 PM
axis11's Avatar
Default Re: Bad A/C
Post the high and low pressures.
Old 07-06-2013, 03:47 AM
Ryan Lwin's Avatar
Default Re: Bad A/C
Before you do anything, go back to the shop and tell them the problem. They should fix it for you.
Old 07-06-2013, 05:14 AM
angrysmileyface's Avatar
Default Re: Bad A/C
If its a 93 and it came with R12 and the shop replaced it with R134A then it efficiency will be terrible. Plus the oils and refrigerant itself does not mix between R12 and R134A.
Old 07-06-2013, 11:44 AM
solblu's Avatar
Default Re: Bad A/C
I agree about the 134 in a 93...who recharged it? Usually the post shops are diy. So you will need to get a few new parts and convert it to 134 properly.
mope
03-09-2017 12:06 PM
Stekis
Acura TL, RL & ZDX
11-27-2005 04:29 PM
integra dave
07-10-2005 10:47 PM
Quick Reply: Bad A/C
