faulty ignition coil??
97 honda civic non vtec
my car doesnt want to start once in a while, i pulled off the cap and rotor to test the ignition coil... specs are 0.63-0.77 I am getting .9 for the primary winding and the secondary winding is within spec dont remember exactly what it was.. would that little bit of difference cause a problem??
Re: faulty ignition coil??
Is there bright white spark at all 4 spark plugs?
Click the spark link in my signature. Did you subtract the internal resistance of your multimeter?
put everything back together and it started. Looks like its a morning problem? could it being cold affect certain part of the ignition??
ok, so ive been messing with it for a while, i have spark... what i dont have is ground signal at the injectors??
my fuel pump wasnt priming so i bypassed the relay (fused with a switch) so i have fuel pressure. If i touch ground to each injector they will click open and car will start but wont start back up after i turn it off
any ideas??
any ideas??
Technical Hero
Sounds more like main relay
http://techauto.awardspace.com/mainrelay.html
i put the main relay back how it was (not bypassed) and the turn the key to on.. anywhere from 30 seconds to a minute or 2and it clicks and starts to prime the fuel pump? sounds like the main relay is bad, but when i had put in a new one it wasnt doing anything??? what else could affect it.. already cleaned ground g101 or somthing like that (thermostate ground)
bk7794
11-13-2012 08:38 PM
