wont go in gear
Old 03-03-2006, 09:12 AM
Lmgrcivic's Avatar
Default wont go in gear
I destroyed my clutch and got a new one had the flywheel resurfaced, new disc and pressure plate. and everything. wouldnt go into to gear when car was started put in a new master and slave cylinder and new shift linkage and still no luck. I bleed the clutch and has a ton of pressure but then when you start the car it loses some of the pressure any ideas guys.
Old 03-03-2006, 09:15 AM
BlueIntegraBoy's Avatar
Default Re: wont go in gear (Lmgrcivic)
Maybe there's a leak in the clutch line?
Old 03-03-2006, 09:20 AM
MakinAComeBack's Avatar
Default Re: wont go in gear (BlueIntegraBoy)
Possibly a leak, also are you sure you put everything back together correctly, such as the pilot bearing?
Old 03-03-2006, 09:54 AM
Lmgrcivic's Avatar
Default Re: wont go in gear (IPB Racing)
if the pilot bearing wasnt in right wouldnt the tranny not go on right
Old 03-03-2006, 10:56 AM
oh your right sorry i meant throw out bearing
Old 03-03-2006, 11:30 AM
Lmgrcivic's Avatar
yeah the throw out bearing is good and in place right
Old 03-03-2006, 03:19 PM
Lmgrcivic's Avatar
anybody have any ideas
Old 03-03-2006, 05:47 PM
Imperious: Mod of Valor
JDM-EJ1's Avatar
Synchros perhaps?
Old 03-03-2006, 07:28 PM
Syndacate's Avatar
if it's the syncro mesh, he could put it in w/o the clutch after revving it to a certain RPM level, redline it, then push the shifter up into 1st as the tach falls back from the redline, eventually, it should slide in, even w/o the syncros, u'll probably spin the tires, but what the hell.....Also, does it go in when the car is off?
Old 03-03-2006, 11:38 PM
zoolander's Avatar
Default Re: (Syndacate)
does the pressure go back up when you turn the car off and then back on...if so, probly not a leak. more so the synchro
Old 03-04-2006, 03:40 PM
Lmgrcivic's Avatar
Default Re: (zoolander)
no the pressure doesnt go back up and also Ive tried 2 different tranny's and I know the one is good for sure so it cant be the syncro's. could something else be lined up wrong or something is there anything else that could be that might not be engageing the whole way
Old 03-04-2006, 04:02 PM
Syndacate's Avatar
get two people to check that linkage, one shifting it, one underneath making sur eit's all working, that's the only thing left that I can think of, if you swapped the trannys with 2 different trannys, I mean, it has to be somewhere in the linkage
Old 03-04-2006, 07:07 PM
zoolander's Avatar
i'm thinkng it might be a leak in the line or slave cylinder, and no pressure to engage. If the lines were okay, then the pressure wouldn't build back up.
Old 03-07-2006, 02:10 PM
Lmgrcivic's Avatar
ok so Im pretty sure that there is some kind of air still in the line. has anyone ever used a bleeder on the clutch before and if so what kind
Old 03-07-2006, 02:23 PM
gunnis's Avatar
Default Re: (Lmgrcivic)
I would think, in bleeding the clutch you would be able to tell if it was building pressure and holding it. If not, yes perhaps a leak is present.
double check your axles. Ive heard of some weird, not going into gear when an axle popped out after an attempt, at changing them, probably not the case.
Good luck.
Old 03-08-2006, 01:06 PM
Lmgrcivic's Avatar
Default Re: (gunnis)
Well guys I got it last night I thank everyone for there help. and I feel dumb that I never checked this but it was the REAR MAIN SEAL. thanks again everyone
fminusmic
14
02-01-2022 05:07 PM
CivicxTree754
10-09-2016 03:21 PM
Getownit
37
02-10-2011 07:01 PM
G-Robinson
Transmission & Drivetrain
04-26-2009 07:52 AM
The Destroyer
18
02-24-2006 06:26 PM
Quick Reply: wont go in gear
