whats wrong?!?!
whats wrong?!?!
people told me its the driver side wheel bearing but heres whats wrong... when i drive the steering wheel shakes.. vibrates... wen its goin striaght theres a weird noise but wen i turn it slightly to the left.. the nose and vibration goes away... what do you guys think is wrong?
grammer nawzi
Re: whats wrong?!?! (O RLY)
You could always do an aligment and balance your wheels and see if the vibration goes away. Might have to replace an axel. Has the car been in any accidents or have you clipped a few curbs?
well i just bought it... its been in an accident.. at first they said it was the axel but then they said it was the wheel bearing.. could it be the wheel bearing?
Re: whats wrong?!?! (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">You could always do an aligment and balance your wheels and see if the vibration goes away. Might have to replace an axel. Has the car been in any accidents or have you clipped a few curbs?</TD></TR></TABLE>
i think thats good advice it could be a number of things wrong so start eliminating the cheapest things to fix first like alignment and balance.
If it's a wheel bearing you should hear a screaching noise. If it has been in an accident it depends on how bad. Somtimes the chassis gets tweaked and you need to align it. Sometimes it gets tweaked so bad you can never align it. Balance the tires and do an alignment, that is the first thing. However, bent axle might make it shake that bad. Did you buy it off a lot or private party?
Re: (ahloung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung »</TD></TR><TR><TD CLASS="quote">private party... i do hear scratching noises along with a louder noise whcih goes away if i turn my steering wheel slightly to the left..</TD></TR></TABLE>
its your axle
its your axle
I feel like an ***, I had this problem in my eclipse, they were able to replace it at tire discount, though I forgot what it was..... Sorry, if I remember correctly it's a small piece, forgot which, not a whole axle though :-\
Sorry, if I had a schematic I could point it out, hehe, GLGL
Re: whats wrong?!?! (ahloung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung »</TD></TR><TR><TD CLASS="quote">is this the axle? i need to buy it ASAP.
Yea that's an axel, I have one if you want one. 40$ shipped. Just let me know.
Very easy to do on your own. Can be done in under an hour. I can do it in like 20 min now.
Axle replacement Tutorial
Re: (ahloung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung »</TD></TR><TR><TD CLASS="quote">could it be the wheel bearings tho? is that a possibility?</TD></TR></TABLE>
yes it could be possibility. when the wheel bearing goes out, it makes a howling sound. the sound changes as you turn the wheel....
its your axle had the same problem but mine was alot worse when i barely turned the wheel to the left the car had like a mind of its own and just yanked hard left and made some bad noises too it got pretty dangerious so then i replaced the axle and the problem was fixed no vibrations or crazy left turns out of no where
It's your axles, buy a remanufactured one from Kragen or something and get the warranty along with it. <FONT COLOR="RED">DON'T</FONT> buy a used axle, because you don't know how many miles are on it.
taguchi09
07-19-2011 06:44 AM
sevwen7
06-21-2011 03:46 PM
Jamezvtec
Honda Civic (2001 - 2005)
06-11-2009 04:43 PM
MSP
15
07-19-2006 09:52 AM
