Lights dims after gsr swap?
I've noticed that after I swap a gsr into my 96 hatch, the lights starts dimming (headlights, cluster, interior). i.e. when i let go of the gas, idle drops. I thought that it was bad grounding so i cleaned up all the dirt and ground them again but yet it still dims. Then i bought a NRG grounding kit thinking that it would work but yet it doesn't. My friend also have the same problem. Anyone know what to do to fix this problem?
Location: Why so you can pretend like youre interested, FL/OK
Use a multimeter on the battery and test for significant drops in voltage. This is a far guess, and this is absolutely shooting in the dark due to the information, but have you checked the alternator. You may want to pull the cables off the battery and see if the car cuts off or not.
Re: (INVALID)
there is a thread that mention this...it stated that you need to unpin A16, if i remember correctly...let me find the link...
edit: https://honda-tech.com/zerothread?id=838099
Re: (JDMFreak)
mine does the opposite...when im at idle its normal. then when under 50 mph or so only when i gas it the lights dim. then when i let off the gas they get bright. wierdest **** i ever seen. i have a vafc and the volts drop to 12.2 my car runs fine and starts so i just said screw it. but if anyone has any ideas let me know
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">do the cluster lights fluxuate in brightness?</TD></TR></TABLE>
yeah the basically the interior lights and the headlights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">there is a thread that mention this...it stated that you need to unpin A16, if i remember correctly...let me find the link...
edit: https://honda-tech.com/zerothread?id=838099</TD></TR></TABLE>
i'll look more into that
Inline6 Silvia
11-12-2006 11:19 PM
Rwecked
05-03-2003 12:10 PM
