ABS problem
ABS problem
Hi!
I have a EG6 Civic with everything swapped from a ITR.
I have also swapped the ITR ABS system.
The problem is that the ABS works realy slowly, I have the wheel lock for a few meters, the unblok for a fraction of a sec. and block again for an other few meters and so on.
I have no error codes and the system seems to work normaly.
What can it be?
What can it be?
Re: ABS problem (Daniel M.)
sounds to me that you could possibly have air in the system. I suggest either bleeding the system correctly or taking the car to a shop that has a pressure bleeder. ABS systems do NOT like any sign of air or water in them.
