ANTENNA INSTALLATION HELP!
I bought a roof mount antenna similar to the EVO8. i was wondering if anyone knows how to install it on a 96 civic hatch? does anyone know how to take the headliner out? -Thanks
Re: ANTENNA INSTALLATION HELP! (SuperJetBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperJetBlack »</TD></TR><TR><TD CLASS="quote">I bought a roof mount antenna similar to the EVO8. i was wondering if anyone knows how to install it on a 96 civic hatch? does anyone know how to take the headliner out? -Thanks</TD></TR></TABLE>
Yes of course. Basically you will need to remove the headliner and drill a hole in your roof to mount the antenna. Then you will need to run the wires along the roof and maybe down the A-piller to your radio.
Re: ANTENNA INSTALLATION HELP! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Yes of course. Basically you will need to remove the headliner and drill a hole in your roof to mount the antenna. Then you will need to run the wires along the roof and maybe down the A-piller to your radio.</TD></TR></TABLE>
just like he said, you'll need to remove the light gray panels the visors and the dome light, there should be a big plastic screw looking thing which you'll have to turn i believe 90 degrees and then its just clipped up so just pull gently and it should come right down
SuperJetBlack
02-28-2006 05:25 AM
