spun rod bearing or main bearing?
I recently purchased a block with a spun bearing and I was wondering if there was a quick way to tell if it is a rod or main bearing, before I become a mad scientist and tear it apart? I don't know if this will help any, put when I push down on the top part of the pistons only #4 moved a couple centimeters.
Thanks
Thanks
Re: spun rod bearing or main bearing? (ntrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrider »</TD></TR><TR><TD CLASS="quote">I recently purchased a block with a spun bearing and I was wondering if there was a quick way to tell if it is a rod or main bearing, before I become a mad scientist and tear it apart? I don't know if this will help any, put when I push down on the top part of the pistons only #4 moved a couple centimeters.
Thanks</TD></TR></TABLE>
A couple of centimeters? Is that without the crank moving?
Re: (B16Drag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Drag »</TD></TR><TR><TD CLASS="quote">put it on an engine stand and become a mad scientist and rip it apart from the bottom. thats the best way to tell.</TD></TR></TABLE>
And pretty much the only way to tell. If the rod bearing is spun, you just need a new crank, piston(s), and bearings. If it's one of the main bearings the block is trash.
Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">And pretty much the only way to tell. If the rod bearing is spun, you just need a new crank, piston(s), and bearings. If it's one of the main bearings the block is trash.</TD></TR></TABLE>
You will also need a new rod(s).
Re: (RTI)
thanks for the replies.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">
A couple of centimeters? Is that without the crank moving? </TD></TR></TABLE>
When I pushed on # 1, 2, and 3 nothing moved only four so I believe that the crank did not move but I am not sure so looks like spring break I am a mad scientist. I will try to do a write up on it, I will keep you posted.
Fishy_hondaman
Engine Machining & Assembly
09-18-2016 10:05 PM
