Engine mount play...normal or not?
Should you be able to move the motor at all by rocking it back and forth with just your arms? I didnt notice any movement on the passenger side of the car, but on the drivers side upper mount I can move it acouple millimetres. I tightened the bolt on the upper driver mount, but it still has the play.
Is it normal or should it be rock solid?
Re: Engine mount play...normal or not? (Cee_mon)
yea, same **** happen to my motor. It appeared my engine MOUNT was broken and thats y it move back and forth like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon »</TD></TR><TR><TD CLASS="quote">Thanks ^
So Iam guessing its suppose to be solid?</TD></TR></TABLE>
yes the motor is not suppose to moved. the more solid the better.
Re: Engine mount play...normal or not? (LLEO245)
THE MORE SOLID IT IS THE BETTER. YOU DON'T WANT YOUR ENGINE FLOP'N AROUND WHILE YOUR BOUNCING UP AND DOWN DUE TO LOWERING YOUR CAR ON THE ROAD AND HAVE **** GOING LOOSE.
balistic CRX
12-27-2001 04:37 AM
