Superchaged- which oil weight?
Which oil weight should i use? The normal that I have been using like a Castrol syntec 5W30 or are you supposed to change it for supercharded applications. This is a JRSC on a B16A2.
Thanks in advance for the help.
If your going to just insult then get the expletive off my post. Im here for help.
Re: Superchaged- which oil weight? (CBEengineering)
Ive been burning off oil I was a quart low since my last oil change. Which was a couple months and within 5k miles
Re: Superchaged- which oil weight? (need4hondaspeed)
do a compression and a leakdown tesk. if both are good id say it wouldnt hurt to step up to a 10w30 weight oil
Not supercharge related, but force induction related. Some turbocharged guys still run 5w30. But me I'm running 10w40, just because I feel like it.
try the "recommend oil page" at http://www.opieoils.co.uk and specify everything about your engine and what mods you have too. he'll suggest the best (full synthetic) oil weight to keep it in good shape
Yeah I'm w/ that other guy, I'd recommend running a slightly heavier oil (10w40) b/c of the FI there will be increased stress on things and a heavier weight oil can spend more time cooling things off....
Re: (Syndacate)
Good Points thanks that what i needed Ill check that page out too JoeNg79
Syndacate thats a good point more too cool off things.
Thanks for the input everyone
EG-SIXV-TEC
11
12-13-2012 02:45 PM
YoshiiEK
06-18-2008 11:44 AM
