After changing the input shaft bearing.....wont go into reverse and is alot harder to put into gear.
Any have any suggestion or tips before i go digging back into this one? Thanks....it is a 97 civic cx
Re: After changing the input shaft bearing.....wont go into reverse and is alot harder to put into g
You didn't put it back togther right.
You didnt line up part #5 correctly I belive.
ya if you dont line them up then it will not go into gear. just take your time.
it WILL go into gear....but it is hard and it will not go into reverse......what do i need to line it up to? I will check it out...thanks for the info.
dcraige
04-02-2010 06:32 PM
