Weird pinging noise?
4dr with z6 head, freshly adjusted valves. the problem is when i shift into a high gear to cruise or at low rpm when i try to accelerate this weird pinging noise happens. and it continues until about 3k rpms. any ideas what it might be?
Re: Weird pinging noise? (nutball72)
what block are you using? depending on what block you used for the mini me, the compression might be high and you are pinging. try pumping in 91 octane and retard the timing
Re: Weird pinging noise? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">what block are you using? depending on what block you used for the mini me, the compression might be high and you are pinging. try pumping in 91 octane and retard the timing</TD></TR></TABLE>
You are definately detonating. Retard your ignition timing.
kls023
08-25-2009 10:22 AM
Mr.Milton
39
09-10-2007 11:03 AM
eortizr
08-12-2005 01:44 AM
wootcivic
10
03-17-2005 04:57 AM
