Spoon Sports Lower Front Tie Bar [HELP]
1 Post
remove the 2 inner lower control arm bolts, put the bar in, replace the bolts to hold the bar in. have the front of the car off the ground and have a friend help if you are not strong enough to move about 50 lbs of weight with one hand.
Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">remove the 2 inner lower control arm bolts, put the bar in, replace the bolts to hold the bar in. have the front of the car off the ground and have a friend help if you are not strong enough to move about 50 lbs of weight with one hand.</TD></TR></TABLE>
Yup. Pretty simple. Good luck
CRX EF 88
12
02-20-2008 05:54 AM
JDubya
09-02-2002 04:37 AM
