Syncro's going at 102,000?
just had a question bout syncros. if im rolling forward even the littlest bit and put it in reverse, it grinds. would a certain tranny fluid help?
be professional
Re: Syncro's going at 102,000? (EKEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKEJ6 »</TD></TR><TR><TD CLASS="quote">just had a question bout syncros. if im rolling forward even the littlest bit and put it in reverse, it grinds. would a certain tranny fluid help?</TD></TR></TABLE>
Umm . . . don't put the car in reverse while it is moving?
be professional
Re: (EKEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKEJ6 »</TD></TR><TR><TD CLASS="quote">well it seems to grind more then it schould...</TD></TR></TABLE>
It won't grind at all if both transmission shafts aren't moving when you select the gear . . . duh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKEJ6 »</TD></TR><TR><TD CLASS="quote">no like it does it when im stoped too, and sometimes its kinda hard to get it in too</TD></TR></TABLE>
every honda Ive ever driven, doesnt always like to go into reverse...just something Ive gotten used to with them all
i always put my car in 1st gear then reverse goes in smooth everytime
also i noticed if you try to put in in reverse when your ebrake is up its a little hard this is in my car but just something to ttry
Re: Syncro's going at 102,000? (winnerpl)
Well according to the car manual that should be in you glove box, it says that you should stop completly before shifting into reverse. It also says if the grinding is persistant when stopped to but the car in a forward gear first(while not moving) to stop any gears that are still spining from moving forward. So it sounds like Honda knew that it will grind in revo, probably even when the car was brand new.
318 Curves, 11 miles
Re: Syncro's going at 102,000? (ak47autolock)
I believe I remember hearing somewhere that reverse on most hondas doesn't have a synchro. If so, you're going to have a slight grind on reverse.
My 2000 EX has grinded reverse from 7200 miles (when I bought it) to 151000 miles. Sometimes it doesn't want to go in at all. If I put it in another gear, pull it out of gear, disengage the clutch, reengage the clutch, and try reverse again, it usually goes like butter. I am almost certain this is the way it's supposed to be.
You can try GM synchromesh if you're really concerned about it, but it'll still grind reverse.
Go Tigers!
Re: Syncro's going at 102,000? (Vindicator9000)
Try reading the handbook that comes with your car, you'll find some interesting stuff in there.
Re: Syncro's going at 102,000? (Bense)
The reason why your reverse grind while your moving on first gear and throw it into reverse without stoping is because there is no SYNCHROS on reverse to stop for the tranny to move from one place to another. Unless you have a magical fluid that will put Synchros into reverse den you're **** out of luck buddy.
superhatchbackbros
10
05-30-2006 10:19 PM
vtec_racer_2kgsr
09-16-2003 05:56 PM
