help w/intake setting...
ok, the motor is the stock cx motor in a 99 civic hatch, and a while back a friend of mine told me i could adjust that screw behind the throttle body to make it quicker while rolling. well now i've messed with it a few times to get more/less air, got into a wreck and had to redo my whole a/c system and my car bogs with the a/c on, so i'd like to put that screw back to stock position. my question is is there any way to put it back to stock, like how many complete turns from all the way down or up? anyone?
Re: help w/intake setting... (99_hb_on_air)
also, i will be turbo'ing this in mid-august , so i'd like to get this solved by then, although i am puttin on a y8 mani. anywho... input is appreciated regarding the intake control
Re: (99_hb_on_air)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_hb_on_air »</TD></TR><TR><TD CLASS="quote">nobody @ all?</TD></TR></TABLE>
Can't help you, get ahold of a helms manual or something that would be the best bet
there is no stock setting, factory calibrated for each particular vehicle. keep playing w/ it a little bit each day and eventually you will get it right.
now i've got it to where it doesn't necessarly bog with a/c on, but it doesn't seem to accelerate like it should guess ill just keep adjusting it. thanks.
macdaddydelux
11-09-2007 07:23 AM
ryaninsocal
12-17-2005 06:52 PM
