taking apart folding mirrors for EK
does anyone know how to take apart the folding mirrors? i took the 3 screws on the bottom out and still nothing.. is there more behind the mirror i have to do? if so how do i take off the mirror? any help would be appriciated..
Re: taking apart folding mirrors for EK (EK9-Stealth)
If you are going to take them completely apart you have to remove the 3 pins from the white connector. Dont make the mistake of cutting the wires just be patient with the pins and remove them with a paperclip or sharp pointy tool.
Re: taking apart folding mirrors for EK (ELUSIVESIR)
im not even that far yet... im tryin to take the folding part off the base. Its still stuck together.. how do i make them into two pieces? thanks for the post..
ok, im at work but this is how i remember how to take them apart once they are off the car:
remove pins from connector
take 3 screws from beneath the mirror to seperate the base from mirror
then gently remove mirror from pins holding it from the inside
then you'll find some more screw beneath the actual mirror
take those out and then you should have a total of 6 pieces in front of you
1. white connector
2. base that attached to car
3. mirror itself
4. motor inside mirror
5/6. 2 pieces that hold the mirror and motor
1. white connector
3. mirror itself
o k.. i found out how to take the mirror off.. you pull from the bottom out, then down. The three screws from the bottom should release it from the base? mind is still together.. maybe im scared of breakin them..
Re: (EK9-Stealth)
cool man if you need anymore help just give a call. i've dealt enough with jdm mirrors so i know them pretty good, some are a pain and some are cake. glad to see you got them apart
thanks for the help..
these are the steps just incase anyone else needs them.
1. pull mirror from the bottom out, then down.
2. take out screw right under the wire.
3. remove pins from white connector
4. remove 3 screws from bottom of the base.
5. pretty much it.
5. pretty much it.
IS IT AT ALL POSSIBLE TO TAKE APART MANUAL (U.S.) SIDE MIRRORS AND REMOVE THE INTERNALS TO RE-INSTALL THE JDM POWER FOLDING INTERNALS INTO THE U.S. SHELLS?
Powered by Honda
07-15-2003 02:11 PM
Mugen(HCA)
06-08-2002 02:54 PM
