eg b16a2 wont go into gear.
Okay. I just finish this swap 2 months ago and everything was fine. drove it for 2 months. Change tranny fluid. only used honda MTF. By the way its stock clutch/pressure plate. I was moving out of the drive way and out of nowhere it wouldn't go into gear anymore. If I press on the clutch I can't shift into gear, but it shifts smoothly when engine is off. All the fluids are full. One thing that was odd was that the clutch felt kind of loose. Like there wasn't any pressure when step on like before.. I'm thinking its the pressure plate? Have no clue. Any help would be great right now.. thanks..
Modified by Bigballars at 12:33 PM 7/7/2006
Re: eg b16a2 wont go into gear. (Bigballars)
can u hear it go into gear but not engage. if you cant even put the shifter into gear then your shift linkage may have came out. Other wise you might have burned up the clutch, i just recently did it and my clutch pedal was loose but it wouldnt engage any gears .... what noises do you hear when you try to put it in gear ?
Re: eg b16a2 wont go into gear. (vandersmissenc)
theres no noise.. its stiff like something is blocking to go into gear. even when pressing down the clutch. I dont want to force it in. I tried starting the car in first gear while holding clutch but when I Started the car it jerk and grind.. it could be the spring, but I'm not sure.
it's the clutch, change the clutch.
The spring on the clutch must have broked. Had the samething happend to me.
zakl
02-20-2014 01:48 PM
ouprimetime
07-08-2004 09:57 PM
