Intake manifold.
Intake manifold.
Im taking the head off my d16z6 and was wondering how I go about getting the last bottom nut off of the intake manifold. I cant seem to reach it. How do you guys get it off? and when and if I get that nut of do I just pry the two loose with a prybar or screwdriver?
No Sales Forums
Re: Intake manifold. (soulforce)
you may have to go from the bottom. We usually just use a uni 12mm & an extention. Also make sure you removed the black brace between the manifold & the block before this nut. That should make it a little easier for you.
I finally got the nut loose but im having trouble with the fuel hose going from the fuel filter to the fuel rail. how do I get this off? I already relieved the pressure.
Unceasing Measure
Re: (soulforce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulforce »</TD></TR><TR><TD CLASS="quote">I finally got the nut loose but im having trouble with the fuel hose going from the fuel filter to the fuel rail. how do I get this off? I already relieved the pressure.</TD></TR></TABLE>
take the hose off from the fuel-filter with a 17mm socket. What's confusing you?
im taking the intake manifold off too.
I went out and looked and I dont know where you want me to use a 17 mm socket. Do I not just pull the hose out of the metal fitting?
Re: (soulforce)
The fitting on the fuel rail is a 17mm. Also on the fuel filter. You should have taken everything off the intake manifold before you desided to take it off.
Ryan Lwin
32
02-01-2013 02:23 PM
LS1Bait
01-15-2009 07:04 AM
