motor oil question?
motor oil question?
i have D16y7 with just about 300,000 miles on it. it burns alot of oil. i use 5w-30. i was wondering if i put synthetic oil in my car would it burn less oil? thanks.
Re: motor oil question? (EK tommy)
Using synthetic may actually make it burn more because the syn has better detergent agents and could breakup oil deposits around seals and such. I don't have proof that this happens, but I have heard of it and it does make some sense. I would switch to 10w-30 or maybe even 10w-40. With mileage that high you definately need something thicker than 5w-30.
edit: are you sure it is actually burning all this oil or is some just leaking externally?
Re: motor oil question? (19dabeast85)
edit: are you sure it is actually burning all this oil or is some just leaking externally?[/QUOTE]
when ever i accelerate hard white smoke comes out of the exhaust.
try that high milegae stuff?
http://www.quakerstate.com/pag...e.asp
http://www.mobil1.com/USA-Engl....aspx
http://www.pennzoil.com/produc....html
http://www.valvoline.com/pages...uct=7
http://www.valvoline.com/pages...t=101
http://www.castrol.com/castrol...30822
Yea, I know I put effort in this... but I have the same problem... no smoke, but I burn alot of oil 230,000km... maybe I hit vtec to much?
i have the same problem someone told me that thier is to much fuel going into my cylinders i night have a injector leaking im ot sure if hes right but can this cause my oil to burn up like that
JohnQPublic
03-01-2006 07:24 AM
