Dropping motor from the bottom, 96-00 EK stock motor
pretty sure i got everything that would be in way and ready to drop the motor out from the bottom. i loosened the two front mounts, removed the bolts on the two lower ones, but not sure what i need to loosen/remove for the rear tranny mount.
can i do this with one jack? it's a michelin 3 1/2 ton jack and got 4 jack stands.
Re: Dropping motor from the bottom, 96-00 EK stock motor (Dudikoff)
i pulled a motor with 1 jack, and some spare tires.
all though i did flip that car on its side...idk if you want to do that?
Re: (19992civichatch)
ok so i need to remove the 2-19mm and 1-17mm bolts im guessing for the rear tranny mount. do i complete remove them? will the motor drop on me lol? the fronts are still on but loosend
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">drop the motor out first b4 you start to move the car...once the motor is actually sitting on the ground, then start to figure out how to lift to front end to remove the motor</TD></TR></TABLE>
yeah need to know if im good to go on the rear tranny mount to remove and if the motor will drop if i do.
Re: (Dudikoff)
lol nobody is reading your question gotta love that... i just pulled my tranny on my ek and yeah those three bolted to the tranny are the ones for the rear mount, take em all the way out. as for it droppin on you if all mounts are loose itd be smart to make sure the thing is supported so it wont drop on you even if it could one jack is probably fine but if you are nervous get two
SOHC_Brian
08-10-2004 10:58 AM
