Fuse Box Relocation Questions (Searched)
I have a few questions i hope you guys can help me with im going to relocate my fuse box to where my air bag (EK) was and i was wondering if you have to take the heater core or a/c condensor out to even see where the wires would come back through the firewall? pics would be
i hope you are speaking about the underhood fusebox going to where your passenger side airbag is. if that's the case i don't believe that you should have to pull the heat/ ac system out to do so although having that stuff outa the way helps. you are prolly gonna have to extend some of the wiring from the fusebox as it is terminated inside the fusebox itself. i know on the older eg's...you can pull the bolts retaining the fusebox in it's original home and GENTLY pry off the retainer clips around the bottom edge of the fusebox and you can get it open. you should see that the wires are already terminated and in their respectives pulgs inside the fusebox. you would prolly have to extend the wiring
