intake problem (nifty diagram included)
i was giving a injen intake. the problem is, i don't have the little o-ring type thing, that fits the air.. thing.. to the body of the intake. (i knew i couldn't explain it.. so i drew you a picture)
it's a good picture.. yes..
where can i get one? can i make one?
Re: intake problem (blackrag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrag »</TD></TR><TR><TD CLASS="quote">i was giving a injen intake. the problem is, i don't have the little o-ring type thing, that fits the air.. thing.. to the body of the intake. (i knew i couldn't explain it.. so i drew you a picture)
where can i get one? can i make one?</TD></TR></TABLE>
WTF? o-ring? there is no o-ring.
Re: intake problem (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
WTF? o-ring? there is no o-ring.</TD></TR></TABLE>
there is no o-ring but there is a plug.
its for OBD2 cars...
Ek Forever y0!
Just plug it and run a breather filter.
That hose connects the two, you can buy a hose that fits or use a breather filter.
Problem solved.
Problem solved.
are you referring to the Intake Air Temperature sensor as the "air plug thing." if you are then you can get one of those O-rings gourments from pepboys/kragen/napa/autozone so the sensor will fit nice and tight on the intake
Re: intake problem (CivicSD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSD »</TD></TR><TR><TD CLASS="quote">i would duct tape it.</TD></TR></TABLE>
how could i stick the little plug in, then?
Re: intake problem (xhatchracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx »</TD></TR><TR><TD CLASS="quote">are you referring to the Intake Air Temperature sensor as the "air plug thing." if you are then you can get one of those O-rings gourments from pepboys/kragen/napa/autozone so the sensor will fit nice and tight on the intake</TD></TR></TABLE>
that's my ish! thanks a lot.. do they carry them in all sizes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx »</TD></TR><TR><TD CLASS="quote">they sure do man, i needed one before thats the only reason i know </TD></TR></TABLE>
where'd you get yours?
Re: intake problem (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid »</TD></TR><TR><TD CLASS="quote">nice intake pic </TD></TR></TABLE>
word. (actual specs used)
Re: intake problem (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson »</TD></TR><TR><TD CLASS="quote">
its for OBD2 cars...</TD></TR></TABLE>
yes i am aware of this, but he didn't say plug, he said o-ring.
Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 »</TD></TR><TR><TD CLASS="quote">you could probably use a small piece of rubber hose too, just make sure the diameters are the right size</TD></TR></TABLE>
that's what i was thinking.. i'm going to a couple local car stores to see if they have anything.. if not.. home depot time. lol
Re: (blackrag)
that's what i was thinking.. i'm going to a couple local car stores to see if they have anything.. if not.. home depot time. lol </TD></TR></TABLE>
Check the Help! section for the grommets in the link above.
trooper0641
05-02-2004 01:27 PM
kotetu
06-17-2003 07:23 AM
