DA rear disc swap
1 Post
DA rear disc swap
I'm a CRX/EF owner and haven't messed with EGs much just a quick question, someone had asked me if the DA 90-93 Integra rear disc would properly fit on a 93 civic hatch...from what I have heard is that the EF and EG rear control arms are pretty similar so I believe it will work but need some confirmation, thanks...Matt
1 Post
Re: DA rear disc swap (jasoncrashtech)
If i get them the rear trailing arms, e-brake cables, Prop valve, Booster and MC from a DA they will be able to use it on there 93 civic
Thats pretty much what I need to know, sounds like its should work out perfect...
#1 Super Guy
Re: DA rear disc swap (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">If i get them the rear trailing arms, e-brake cables, Prop valve, Booster and MC from a DA they will be able to use it on there 93 civic
Thats pretty much what I need to know, sounds like its should work out perfect...</TD></TR></TABLE>
You don't need the MC & Booster for a rear disc swap. You only need a larger MC if your putting integra front brakes on your EG...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasoncrashtech »</TD></TR><TR><TD CLASS="quote">i know the sway bart will bolt in the da lower arms , but wil the bushings bolt to the chassis of the eg. </TD></TR></TABLE>
The rear sway from a DA will NOT work on an EG. The mounting system as well as the bar are both completely different. I also think the DA lower control arms are too long for an EG and that will screw up your rear suspension...
90B16aCRXsi
12-04-2007 03:19 PM
JDMThoughts
03-21-2005 03:41 PM
