Oil pressure and Water Temp Gauge installation
im wondering how everyone is doing theirs, im gonna have a T on the back of my block where my oil pressure sensor is, and the feed line for my turbo, im wondering if i need to get a 4 way adapter for the line on the mechanical oil press gauge
and on the water temp i know it comes with a fitting to tap into a water line or supply, im wondering where to tap this into?
thanks in advance
thanks in advance
i tapped my water temp sensor into the front upper radiator hose neck,the one that unbolts with 2 bolts on the passenger side of the head.just take it off,and drill adn tap the hole.i used mine like that for like a year w/ no problems.
Re: Oil pressure and Water Temp Gauge installation (TunerShark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark »</TD></TR><TR><TD CLASS="quote">im wondering how everyone is doing theirs, im gonna have a T on the back of my block where my oil pressure sensor is, and the feed line for my turbo, im wondering if i need to get a 4 way adapter for the line on the mechanical oil press gauge
thanks in advance</TD></TR></TABLE>
I had a 3 way tee for my oil. Stock pressure sending unit, oil feed and feed for the gauge. For my water temp, I had a pipe with a tapped hole to screw the sensor in and placed it in the upper rad hose
Re: Oil pressure and Water Temp Gauge installation (specv5150)
For oil yeah just use a t fitting and run the line through firewall.
For the water temp another possibility might be to use the bleed off for the coolant but I have no experience in that just offering a suggestion of difference.
Re: (jsnm)
thanks for the advice, im sure ill get it to work somehow, waht about the oil pressu sensor? you think a sandwich adapter would work out fine?
SB97civic
01-02-2004 08:40 PM
SJR
10
02-12-2003 07:52 AM
JM Performance
03-14-2002 10:32 AM
