would the knock sensor cause vtec not to work??
I have a 97 dx coupe and just got done putting a d16y8 in it! vtec is hooked up but not working its like the ecu is putting the rev limit to 5000 rpm and im lost...need help. I used a 96-98 ex harness and ecu. the knock sensor on the motor got knocked off and im getting one this week sometime but i need help!!
Re: would the knock sensor cause vtec not to work?? (1clean_ Ej)
vtec will still kick without knock i beleive just not as hard as it should..as for ecu, what are you using? And are you sure you have vtec hooked up right, cause if vtec isnt hitting and you hit a rev limiter about 5K, or whatev your ecu is supposed to hit vtec..then i think you have it hooked up wrong, possble having the pressure wire going to the solnoid and the solnoid wire going to the pressure switch..double check your wiring for sure
Re: would the knock sensor cause vtec not to work?? (GreyDel)
ok...im an idoit...i didnt see that you are using a EX harness and ecu...so its all plug and play, you didnt have to hardwire in vtec..
yea i dont know man but the car is running but it's not right i don't know whats goin on like i said im lost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel »</TD></TR><TR><TD CLASS="quote">vtec will still kick without knock i beleive just not as hard as it should</TD></TR></TABLE>
VTEC is not like your weiner, its either on or off. If the knock sensor is bad, it'll throw a code or send your car in limp mode, and that means absolutely no VTEC.
Re: would the knock sensor cause vtec not to work?? (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">
VTEC is not like your weiner, its either on or off. If the knock sensor is bad, it'll throw a code or send your car in limp mode, and that means absolutely no VTEC.</TD></TR></TABLE>
you are correct.
i hate when people say "vtec is not hitting as hard"
you are correct.
i know...its not hooked up bc its broke off im getting a new one this week sometime i dont know whats up with the 5k rev limit tho like i said im lost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1clean_ Ej »</TD></TR><TR><TD CLASS="quote">i know...its not hooked up bc its broke off im getting a new one this week sometime i dont know whats up with the 5k rev limit tho like i said im lost.</TD></TR></TABLE>
limp mode...
limp mode...
vtec will not engage w/o a KS. it is not reliant on that sensor(as far as i know) BUT
W/o a KS, factory timing advance will not increase like it should. the ECU wont let high rpm's happen with no input in knocking noise, almost like a limp mode when a strong knock is heard. Sounds like the KS kiddo. Just my input, not sure about correctness though...
Re: would the knock sensor cause vtec not to work?? (APCforthewin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APCforthewin »</TD></TR><TR><TD CLASS="quote">vtec will not engage w/o a KS. it is not reliant on that sensor(as far as i know) BUT
W/o a KS, factory timing advance will not increase like it should. the ECU wont let high rpm's happen with no input in knocking noise, almost like a limp mode when a strong knock is heard. Sounds like the KS kiddo. Just my input, not sure about correctness though...</TD></TR></TABLE>
there is no correctness...
if it throws a code for knock vtec will NOT work.
so it could be the ks not letting it go over 5k right? ill get one sometime this week and hope thats it anytime else it could be on the ecu problem???
Re: would the knock sensor cause vtec not to work?? (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson »</TD></TR><TR><TD CLASS="quote">
if it throws a code for knock vtec will NOT work.</TD></TR></TABLE>
sorry i got technical...
just got it in and goin to get it checked tommorw so i dont know yet but i know in ks is not hooked up and the air change sensor or something and thats it everything else is hooked up.
Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">dudE! DO YOU HAVE A CEL!!?????? if you do, then that is your problem!</TD></TR></TABLE>
i know but i just got it in tonight and im get it checked tommorw so ill see from there. and i know one is the knock bc its not hooked up!
Re: (APCforthewin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APCforthewin »</TD></TR><TR><TD CLASS="quote">Is your LS obd1?</TD></TR></TABLE>
dont knoe if this was for me...but yeah it is
2000 LS block
90 sir head
2000 LS block
90 sir head
Actually my knock sensor isn't wired up on my eg6 b16a with a p30 ecu, check engine light comes on and i checked it today and it's the knock sensor, code 23. YET vtec still works, no it's not wired to a switch, it's wired to the ECU!!
Anyways where the hell is the knock sensor so i can go wire mine up??
Its the knock sensor, always has been.
VTEC will not work without it unless it is OBD1, or the ECU is chipped to not read it.
DAM PEOPLE! It isnt hard.
