speed sensor?
speed sensor?
well i havea problem.. i just bought another eh3, and my speedometer doesnt work. and the cluster works fine, ive tried it in my other hatch... my speed sensor is hooked up.. what could be the problem?
Re: speed sensor? (hip_hop_s0ulchild)
Bad VSS, what else doesnt work on the cluster just the speedo? And when its on your other car the speedo works fine? Did you try your other cluster in that car and see if it works? If it doesnt then check wiring as well as sensor.
make sure all the connections on the plug that hook to the speed sensor are good. clean the plugs on the male and female end also
ryrex02
12-07-2010 05:53 PM
