How do you swap an OBD2(civic si) into an OBD1(1992 hatch)? Do I need to convert od change anything?
I don't really know what to do. Should i change or need anything....should i convert or re-wired my harness...tell me
u don't need to do anything, i'm not sure if the civic si engine harness will fit into the eg shock towers, but the integra obd2 engine harness does fit though. u have two choice, either one, get an integra gsr engine harness and plug and play or two, convert ur engine to obd1. that is intake manifold, alternator, distributor, injectors, and etc. but if u don't want to deal with so much stuff, just go ahead and get an integra gsr engine harness and you'll be good to go. be sure ur using a obd1 ecu though, u'll be needing a usdm p30 ecu off of del sol b16vtec to pass ref'd and smog.
readyjetsgo
24
10-03-2014 10:14 AM
Choy
02-25-2010 03:07 PM
hondarookie10
10-26-2003 06:14 PM
