is this a good turbo setup for b16
Old 11-22-2007, 10:55 PM
tigueremalo's Avatar
Default is this a good turbo setup for b16
Brand: Garrett
Model: T04B
Compressor A/R: 0.60
Compressor trim: V (63)
Internally wastegatable: NO
with stock internals.....??
Old 11-22-2007, 11:01 PM
numberone's Avatar
Default Re: is this a good turbo setup for b16 (tigueremalo)
You have too many posts to not know that thread should be in Forced Induction
Old 11-22-2007, 11:02 PM
Default Re: is this a good turbo setup for b16 (numberone)
noob to the turbo info ****!!!!! ma bad
Old 11-22-2007, 11:12 PM
Doostur's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numberone &raquo;</TD></TR><TR><TD CLASS="quote">You have too many posts to not know that thread should be in Forced Induction </TD></TR></TABLE>
https://honda-tech.com/zeroforum/16
Old 11-22-2007, 11:19 PM
93egSLEEPER's Avatar
thats a pretty big turbo for stocks....
Old 11-22-2007, 11:22 PM
Default Re: is this a good turbo setup for b16 (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">thats a pretty big turbo for stocks....</TD></TR></TABLE>
how i wanna make a at least 300whp daily driver and on pump gas....?
Old 11-22-2007, 11:25 PM
a midsize t3 is pretty big on stock internals... what motor are you running? im going to use something in the GT28R size and ill be close to 300 whp on a B16
Old 11-22-2007, 11:27 PM
2000 b16a2 bone stock
Old 11-22-2007, 11:29 PM
Doostur's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo &raquo;</TD></TR><TR><TD CLASS="quote">
how i wanna make a at least 300whp daily driver and on pump gas....?</TD></TR></TABLE>
Get a GT28RS or GT30R.
Quick spooling and will meet power goals with room to grow.
Old 11-22-2007, 11:30 PM
okay... im running JDM B16 block w/ 2000 A2 head w/ mild port and vavle job w/ everything else stock. the shop i go to said they can get 300 whp from my motor w/ the right turbo and a good tune. the turbo they wanted to run is around the size of the GT28R which will spool around 4200. i also plan on running bigger cams with it so i might be over 300 whp... not sure. search turbo setups on the site and see what the numbers are ppl have and what they run.
Old 11-22-2007, 11:43 PM
well here is what am thinking
mild porting and head work with GS-R cams probably a block guard
65-70mm throttle body for exhaust 2.5 al the way no cat with a cat back
cleanej2
10-20-2008 03:56 PM
95exdsmkilla
08-14-2008 05:30 PM
kcjohnnyboy
01-25-2006 10:58 AM
Topdawgg
01-23-2006 06:54 PM
radeon
02-18-2005 12:33 AM
Quick Reply: is this a good turbo setup for b16
