check engine light
check engine light
How do I get the check engine light to turn off? I know I should bring it in to get checked out but does anyone have any idea as to how I can turn it off on my own?
Re: check engine light (nyzd79)
well, remove the (-) negative terminal cable of the battery for 10 mins. But if the problem isnt fixed, then u are gonna throw another DTC
Take your car to autozone. I believe they will run it for free to see what code your throwing. You're not doing yourself any favors by hiding the problem, it will still be there. Just fix it then no more light.
Re: (bballchris24)
And again H-T fails to help somebody with a basic question .
https://honda-tech.com/zerothread/1901557
Go there.
Going to a place like autozone, pep boys, advance auto, etc. and getting it OBD-II port scanned with an OBD-II scanner is more efficient as it will give you a more accurate read-out, if your car is OBD-II ('96+). If your car is '95 or less, the OBD-I accuracy in that link I gave you is as accurate as you can get.
Go there.
floatfisher
02-22-2007 08:03 AM
