how to change wheel studs
i have a 92 civic and my wheel studs broke and i am dont know how to fix it can anyone help me. like tell step by step how to change the wheel studs
Re: how to change wheel studs (92civic104)
I think all you have to do is take the wheel off, then remove the brake assembly, then take a hammer to it and beat it out...pop the new one in and put everything back on.
Resident Gearhead
Re: how to change wheel studs (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 »</TD></TR><TR><TD CLASS="quote">I think all you have to do is take the wheel off, then remove the brake assembly, then take a hammer to it and beat it out...pop the new one in and put everything back on.</TD></TR></TABLE>
Not enough room to do it this way. You have to press out the splined hub from the bearing to get them out and in.
Re: (instrument)
you could grind off some of the stud where it catches the hub, make a little more that a D shape and beat it in. Not the correct way to do it but I used it on a Sunday, out of town, with little to no tools and drove it home. Worked for me for a year and a half now.
Re: how to change wheel studs (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">Not enough room to do it this way. You have to press out the splined hub from the bearing to get them out and in.
I remember changing one out on a '00 Civic sedan that way...might be different for the earlier models.
<FONT SIZE="5">Here's a very detailed writeup with lots of pictures on how-to do it.
> "OMG, Syndacate, where did you find that?"
>> "Well, my friend, it was on the big 'FAQ' thread stickied at the top of this forum."
> "You mean I didn't even need to search and just wasted everybody's time by creating a new topic?"
>> "Yes, and to think, these write-ups were already assembled in the FAQ and stickied for your (and the rest of H-T's) ease."
idiot</FONT>
idiot</FONT>
dont hammer it in from the back.......grab a stack of washers and impact the lugnut on and pull it in and torugh with the gun (tightening) it pops in
Re: how to change wheel studs (civic.slow)
Cant you hammer it in from the back with a rubber mallet slowly so you dont damage the thread? I have a broken stud as well.
I have ARP extended wheel studs and could i just replace all 8 OEM studs by cutting and hammering it in from the back? Has anyone replaced all 8 studs with extended wheel studs doing this method?
