another car won't start thread....
I just drop a 00b18c1 in my 93 del sol. after I put all the plugs in and ecu(p72)
I tried to start the car. It crank for a while and didn't turn over, so I check to make sure I was getting fuel. After I fixed that problem I tried to start the car again and nothing... The fan turns on that's it.... no crank no nothing.... I check all the fues I double check all the grounds. don't know what else to do......
honda-guys please help me out........
Re: another car won't start thread.... (chero112)
You may be having a problem with your starter. Try wiring it directly to the battery to see if it will crank the engine. If not, replace it.
Re: another car won't start thread.... (RonJ@HT)
check and double check and triple check your wiring. after i made sure all of my plugs are in good shape and in the right place i would move on to fuses, then check my grounds, and end with checking my ecu. Did the ecu work before you used it in the car? If there is a blown ECU fuse you might have gotten the ecu too.
your battery sounds like its fine. it could also be ur dizzy.
Re: another car won't start thread.... (obuhmyuh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh »</TD></TR><TR><TD CLASS="quote">haha yesssss!!!!!! Good job </TD></TR></TABLE>
thanx for the help.....you get a form me
hurraquio
02-04-2006 07:34 PM
Audio28
07-03-2003 05:33 PM
