How hard is it to put EX cluster in a DX?
I've got a 94 DX and would like to put in an EX cluster with the tach. Is there anything major that needs to be changed? Does it plug right in or do I have to run wires for the tach like a normal aftermarket one?
Re: (The Lobster)
U serious? That is awesome. All this time I figured I would have to rewire something to get the tach to work. If I knew it was this easy it would have been done a while ago, b/c I couldn't find a place to mount my small aftermarket tach without it looking ghetto.
Re: How hard is it to put EX cluster in a DX? (Nickboxer7)
you could take off the condoms on the bulbs to make it brighter. its alot bright than stock. youll notice the difference.
Re: How hard is it to put EX cluster in a DX? (asentis)
before you put it in, replace the bulbs with amber, or add the amber si condoms, looks so much better
Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">no you take the dx out and you plug in the ex no wiring everything is plug and play. even the Si cluster.</TD></TR></TABLE>
will this work with a 97? I wanna do this to my EK cause i dont wanna resort to an aftermarket tach. Anyone know if theres a write-up on how this stuff wires up?
Re: (H22Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">96-00 clusters are interchangable as well the tachs are pre wired...you can also swap in the older crv clusters</TD></TR></TABLE>
great! now i just have to figure out how it all hooks up and im good to go. No tach kinda sucks
Re: (Apotheosis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apotheosis »</TD></TR><TR><TD CLASS="quote">
great! now i just have to figure out how it all hooks up and im good to go. No tach kinda sucks </TD></TR></TABLE>
Very easy, maybe like 3-4 plugs. The connectors should be different too so it makes it easier to install.
Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
Very easy, maybe like 3-4 plugs. The connectors should be different too so it makes it easier to install. </TD></TR></TABLE>
alright cool. thanks
Re: (Apotheosis)
This diy works good for the amber bulbs. It has that jdm amber look. I did it to my bulbs after I swapped my ex cluster in.
https://honda-tech.com/zerothread?id=661308
Re: (2tonecivic21)
my local junk yard hardly has any civics that are any newer than '90, so that out. I just need to know where i can get a cluster that wont cost me an arm and a leg
I seriously cant believe someone asked this question but hey...to each his down... Plug and play for the win
Re: How hard is it to put EX cluster in a DX? (LSej1)
Another question about this. Will the manual one work on an automatic? Will the only difference be it wont show your gears on the dash?
yankeefan855
05-15-2010 03:55 PM
snarcher!
04-07-2008 11:42 AM
