idle problem
idle problem
i have a ej1 with a z6 motor. the idle bounces from 900-1600 after about a minute after start up til the car turns off. i changed the iac twice and changed the t/b. the top hole in the t/b has a leak, u can hear the air being sucked. if i cover the hole with my finger the idle goes normal also the car used to be auto now manuel and theres a auto p28. what could it be? thanks.
Modified by silverdcteg at 6:20 PM 4/26/2008
Re: idle problem (silverdcteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverdcteg »</TD></TR><TR><TD CLASS="quote">...the top hole in the t/b has a leak, u can hear the air being sucked. if i cover the hole with my finger the idle goes normal...</TD></TR></TABLE>
Okay, what does the top hole of the TB serve? If it is the IACV, then look for a leak in the air passage way that connects the two.
Alternatively, is there possibly trapped air or a blockage in the IACV coolant hose that is preventing proper coolant flow through the IACV?
Finally, might you have a problem with the IACV circuit?
Modified by RonJ@HT at 1:39 AM 4/27/2008
Re: idle problem (RonJ@HT)
goes to the iac but i couldnt have gotten 3 bad iacs. when i cover it the idle evens out like theres a leak there or something
Re: idle problem (obuhmyuh)
motor was in my friends car nd it had the same problem. nd it did the same thing when i had a gsr ecu
Modified by silverdcteg at 3:11 PM 4/27/2008
