TPS CEL. Help
TPS CEL. Help
I have a 92 Hatch with an ls-vtec. and i keep getting code seven(TPS) i checked all the ohms and everything after searching on Honda-Tech to fix this problem. But i still have no luck. Anybody Got any ideas? i have tried three throttle bodies already.
Re: (Horseofcourse)
did you try a new or different tps also check if you didnt switch your map sensor and tps sensor plug. they look the same so its a common problem. everytime you do something different make sure you reset your ecu by removing the neg. bat. terminal or taking the fuse off. what does your car do by the way?
Re: (zero-one)
Why does everybody on honda-tech think that when someone asks a question they are a 16 year old kid working on there first car. You guys need to quit acting like we are all retarded.
Back to my thread.
Any ideas? Please help and be constructive please.
I dont need posts like this:
"Go Search" (Done it found nothing)
"Check this and that"(Read My thread all the way)
Back to my thread.
Have you tried a different ecu....?
I dont know what you want anyone to tell you.
Youve tried different TBs. You say youve checked the wiring.
Obviously something is at fault and the ecu is the only option left.
andyc_0652
11-18-2010 06:54 PM
